Is it possible to connect any radiator on the same side?
Posted: Fri May 08, 2020 9:35 am
Hello,
I'm decorating a bedroom with many problems (other posts will surely follow). The current radiator is connected at the top on one side and the bottom on the other side. This means there is a pipe running underneath the whole length of the radiator. I know this is for maximum efficiency but the radiator is only connected to a wood burner so doesn't get very hot or used much anyway.
Would it possible to connect a standard, nice looking modern radiator on the same side? I had a look online but can only see the old cast iron types connected like this.
