What is large water tank in loft for?
rhogb
by rhogb » Sat Jun 20, 2020 10:04 pm
I have had an air source heating system fitted , I have one large water tank in the loft (I used to have a small tank as well before it was fitted) .
What I want to know is what does the large tank feed. Is it for feeding the radiators or the hot water cylinder.?
Many thanks in advance.
Re: What is large water tank in loft for?
by stoneyboy » Sun Jun 21, 2020 10:13 pm
Hi rohgb
It probably feeds cold water to you hot water cylinder, loos, and any cold tap that is not on mains.
rhogb
by rhogb » Sun Jun 21, 2020 10:49 pm
As far as I know all the cold taps and toilets are run from the main cold water coming in to the house.
by stoneyboy » Mon Jun 22, 2020 10:16 pm
Hi rhogb
In that case it looks like the tank feeds the hot water cylinder.
