Semi-permanent removal of radiator
Posted: Wed Oct 28, 2020 5:11 pm
by POckelford
Hello - I've never done anything more advanced than bleeding radiators before.
I would like to remove a radiator (building cabinet where it is) but keep the pipes/valves in place for eventual replacement on moving etc.
The house is seven years old, on a communal heat-exchange system, so I can't imagine it's a one-pipe C/H system - and I should be able to take away one radiator without disturbing the rest.
Is it as simple as closing the valves (in: thermostatic, set to 0, out: lockshield with little drainage bit, turn to close), drain radiator by opening air valve at top, and little drainage bit on 'out' valve, removing the radiator, capping the two valves?
If so, what am I looking for cap-wise? I've also read about valve clamps for the thermostat end?
Images attached. Thanks in advance for any thoughts.
Re: Semi-permanent removal of radiator
Posted: Fri Oct 30, 2020 10:00 pm
Hi pockelford
Yes your plan to close off ends and drain down are correct. If you can find them its probably best to fit end caps on the valves that are left.
