Overflow pipe from central heating header tank releasing hot water
Posted: Sat Mar 13, 2021 10:36 pm
by Ivornew01
Header tank for central heating over flow pipe to out side hot water being released. Hot water coming from Swan neck piper from hot water tank in airing cupboard, this pipe only releases hot water when central heating comes on to heat rads and hot water to taps.
No discoloured water coming out of hot water taps, Ballcock in tank ok and floats ok. Drained central heating system and refreshed still have same problem, not sure where to look next before I call in professional help.
Any ides would be appreciated, many thanks
Re: Overflow pipe from central heating header tank releasing hot water
Posted: Mon Mar 15, 2021 10:18 pm
Hi ivornew01
The most likely cause is that if you have a perforated coil in the hot water tank.
