which ideal boiler ?
Posted: Mon Mar 26, 2007 7:48 pm
by steveuk1971
Possibly going to replace my system boiler (not combi).
Shortlisted to 2:-
ideal classic he12 vs ideal icos he12 boiler.
Have chosen these as they fit into a standard kitchen wall cupboard which i need.
the classic seems about £100 cheaper (inc vat).
Anybody got any experiences versus both or any particular reason to go for the more expensive one?
Thanks in advance.
Posted: Mon Apr 02, 2007 9:20 pm
by Aarovic
Go for the Icos - it is a well proven modern boiler and the Classic is just an upgraded 'D' rated model.
Ideal Icos system boiler
Posted: Thu Apr 05, 2007 8:54 am
by John Moody
I fitted this boiler new in Feb 2003, and it is very efficient. Our gas consumption is low. But that is mainly because the house has high levels of insulation, and we have a wood burner. The boiler supplies underfloor heating to the whole house. We also have a Solar hot water system.
We had a horrendous break down of the boiler in the winter of 05/06. It kept cutting out, and would not operate long enough to give us any heating.
I called in 3 different Corgi engineers, none of whom could fix it without throwing expensive parts at it till it worked. It was broken down for 9 weeks in the coldest period for a few years.
The Ideal specialist could not help because his lap-top which he uses to diagnose problems with these boilers was being updated by Ideal.
The Ideal technical help-line was no help.
Eventually I got hold of the local Ideal rep, who came here with an Ideal engineer the next day out of sympathy...........I filled his ear with my tale of woe on the phone......... and they fixed it with their lap-top diagnosis. It needed a new gas control valve, which they had in the car.
We were considering changing the boiler out of frustration. Since then it has been fine till this week.
It has started over-heating. The underfloor heating has a cut-off switch to protect it if the system goes over 60 c., and this kept cutting out because the boiler water temp had increased to 63 from the set 55c. The boiler failed to respond when the temp control was turned down.
I was about to call out an engineer when I decided to look in the service/installation manual.
I noted a little electronic component was mentioned to prevent interference by local radio signals. We have just started using a wireless internet device on our computer modem. I put two and two together, turned the wireless box off, and the boiler instantly worked perfectly.
So there you have it. We can't have a reliable boiler, and a wireless internet connection. I'll be getting the little device fitted to our boiler.
I hope the above is helpful to someone.
J.M.
Posted: Sun May 06, 2007 9:32 pm
by knight_eo
the he is only high efficency go for a condensing boiler youll save even more from experience the worchester bosch greenstar is the best
