Motorised Valve Check
Posted: Tue Oct 09, 2007 8:37 pm
by David Wheeler
Any advice?
My radiators get warm when the boiler is on for hot water. I am told it may be the motorised 3 port valve. How can I check this out please?
Posted: Fri Oct 12, 2007 12:53 am
by The Heating Doctor
Do you know where your three port valve is? If so it should be straight forward. If the valve is not close to the time switch you may need help.
Turn your heating on for a minute or two, then off at the time clock if the valve does not move, you will see a lever which will move if the valve is, then that is where your problem lies. You can try moving the lever to see if your valve has got stuck over the summer months.
