No 250V power to the pump
Posted: Sat Oct 13, 2007 4:15 pm
by mallxx
hi I have no 250v power to the pump on my jaguar 23 boiler, The stat is set to call for heat but the pump does not run, i have checked the fuses on the pcb board and are both ok , Can anyone suggest where to check now ? help mallxx
Posted: Sat Oct 13, 2007 9:35 pm
Have you got power going to the boiler, and the PCB ?
If yes, but no power to the pump, then it's a faulty PCB
Posted: Sat Oct 13, 2007 10:05 pm
by mallxx
Thanks for the reply its sorted now,! It turned out to be the room stat either dicky connection to the base pins, or dicky switch not sure which? but now pump is running & all is ok at the moment.Thanks anyway cheers mallxx
