leaky combi boiler and drop in pressure
Posted: Tue Oct 16, 2007 10:06 pm
by squirley
Hi all - I'm new to this so I'll just state my massive problem. LAst year moved into a house with vokera linea combi boiler, the flashy red light and code 4 quite a lot, so I repressurised...many times. Over summer this all seemed fine, not much repressurising needed, only monthly or so, which i can live with. But now it's chilly up here in Scotland and the heating is on a lot and the damn boiler is leaking water out a pipe somewhere directly IN the boiler. Aaaaaand I have to repressurise the thing every few hours or so. My baby woke up last night because it was so cold *brrrrr* and the heating hadn't come on when it should.
anyways - ramble ramble - I need some advice or help. I've downloaded the manual and the installation instructions directly from vokera, but, I couldn't find anything to shed light on the subject.
Someone please help. :(
Posted: Wed Oct 17, 2007 4:40 pm
If there's water leaking from the boiler, then that's more than likely to be the problem. Could be a leak from a joint, auto airvent etc etc. The smallest leak is enough to lose the system pressure.
Try to locate the leak, keep an eye on the pressure, does it rise when in use ? (it will maybe 0.5 to 1.0 bar) but shouldn't be much more than this.
Posted: Wed Oct 17, 2007 9:26 pm
by squirley
the pressure goes up when the heating is on - from what I've read so far on the internet, it looks like a faulty pressure release valve (i think). Plumber phoned today, left a message but no reply :( it really needs sorted, I've collected a tub full of water in just one day and had to repressurise 4 times today alone.
thanks for reply.
Posted: Thu Oct 18, 2007 3:49 pm
if the boiler pressure is rising to above 3.5 - 4 bar then it's probably a fault with the expansion vessel.
Re: leaky combi boiler and drop in pressure
Posted: Thu Dec 15, 2011 1:33 pm
by mobyfagan
my problem is low pressure 0.5bar there is no filling loop it fills from tank in attic gravity feed how do i re pressure boiler
