Hello all
I have a flat with electric only, no gas. Hot water is from an immersion tank. I have no heating, so using oil-filled electric heaters.
I know little about DIY so here's my daft question - can I not have traditional water radiators running off my hot water system? Water radiators in my opinion gives off a nicer radiant heat, which is much better than these plug-in rubbish that I got. Can not the hot water pipe supplying my sink in the kitchen be extended into my lounge to feed a water radiator? I know that it probably would use most of the stored hot water in the immersion tank, but at least I'd have heat and the tank would heat up again in about an hour. Is it possible, and is there a company out there that can do it for me?
Thanks in advance,
Mark
