New radiator problem
Posted: Sat Nov 03, 2007 8:18 pm
hi Folks
I just changed one radiator in my kids bedroom today, the problem is(which i'm sure you heard a million times) is there is NO DAMN HEAT going into it.
I'm no expert in plumbing so i'll tell you what i know
I have a combi boiler system, no tank in the loft.
Pipe is micro bore 8mm
Fitted thermostatic valve 15mm to the new radiator, i followed the instructions but hey no ones perfect!!
All other rads in house would scald your hand to touch except this one and one right outside kids room which is only mildy warm at the bottom.
The thing i find strange is the micro bore pipe coming out the floor in kids room aint even slightly warm!
Tried bleeding it and water comes out straight away so i'm guessing this means there is no air in it.
The rad outside his room i cant bleed because i only got a plastic key and it wont budge it, the last one i tried was metal and it broke too.
So please folks help me out on this one, without the obvious call a plumber or heating guy!!
Thanks mucho!!
Thanks mucho!!
