Any help on the following very much appreciated. I've spent thousands on a new system a year ago and the original plumber no longer keen to help, so hopefully someone out there can.
System: Worcester 28KW system boiler + flowmaster (unvented)
The original pipework has been added to several times but no problems visible. Old house. 3 floors. 20 rads.
Problem: some knocking in the pipes although all the pipes have been secured. the boiler itself is quiet. More annoyingly, two rads on the first floor and one on the second always need bleeding. Pressure does not seem to fall on the boiler but it's a large system with a small extra expansion tank, so perhaps not large enough drop to be obvious.
The tall towel rail in the bathroom is main culprit with sometimes 10 seconds worth of air. There is no sign of water leakage anywhere.
I would like to know: Can air enter the system without pushing out water, if so, how and where?
I suspect a couple of TRVs are sited on the return instead of flow - does that matter if they are reversible?
Do I need a bypass valve? TRVs on every rad apart from bathroom which has, it seems, two lockshields. I have one TRV on 4/5 - higher than the rest to act as a bypass at the moment.
If i fit a valve to automatically bleed air, does that really help, since air is coming in from somewhere?
And can the vent pipe leak air into the system?
If anyone can help, would be great. Thanks Dan
