Electric boiler for hot water supply???
Posted: Tue Apr 03, 2007 9:26 pm
I have just bought a flat but it needs work before I move in and I need some advice. It's a 2 bed place, has one bathroom that needs a complete refurb, and I will be adding one en-suite. Not a new build but all flats in the block have electric underfloor heating - there is no gas supply.
Currently the hot water is provided by an immersion heater alone but I am never around at the same times of day. I don't like the idea of constantly heating a tank of water and not using it, nor fancy running out of hot water mid shower or halfway through running a bath. Also, it would allow me to remove a large airing cupboard which currently takes up a lot of room in the bathroom, so for me it justifies the cost (sure I could relocate the boiler/piping via the kitchen or worst case just downsize the cupboard)?!.
I don't fancy 1 or 2 electric shower units. Would an electric boiler be a possible solution bearing in mind the following:
- It doesn't need to heat the flat as that is covered (would a smaller unit be adequate?);
- Although it will be just me initially, I need to "future proof" the place so have to consider that the hot water output would be adequate to cover powering perhaps 2 showers and a running tap in the kitchen for example;
- Not sure how much pressure I get on the mains water;
Thanks for your time, very helpful site!!!
