Help no Ch but HW
Posted: Wed Nov 21, 2007 11:06 pm
I have just replaced my central heating pump as prior to this I had no hot water or heating. i replaced pump with exact Grundoff replacement.
Now I have hot water again but alas no heating.
I imagine the cause of this is that I need a replacement 3 way valve.
Is there anyway of checking this before spending more money.
The pipe leading from the 3 way valve to rads is cold yet if i open bleed valves on rads the water spurts out:::
I can hear pump moving and have bled the pump??
Is there an electrical test I can perform??
there is also a lever of sorts on the side of the 3 way valve what does this do.. problem is that seems hard to reach and seized.
Any advise or tips thanks Ashley..
