Central heating failure
Posted: Fri Nov 30, 2007 4:12 pm
Hi folks,
My C/H failed big style, after a plumber fitted a new shower pump in the loft and a new immersion tank, the pump appeared to be running, but non of the rads were heating up. The boiler kept cutting out as you could hear loads of air in the system.
The update is as follows - I have fitted a brand new 3 speed pump in the airing cupboard, drained down the system several times and run fresh water from the header tank in the loft, untill the water ran clear. I also tooke off a rad which didn't appear to be filling up properly, cleaned/replaced it.
I filled up the system and hey presto - nothing !! still no heating. The pipe just after the mid position valve is piping hot, but six inches below that it is cold - which makes me think that the water is not being circulated, the boiler (Gloworm 50FF) still cuts out as the water inside it is hot, so it thinks that it has done its job and stops as (i think) it should.
Have i missed something obvious or am i just cursed ?
Has anyone got any ideas that wont cost several hundred pounds .
