Hot water cylinder.
Posted: Mon Dec 03, 2007 9:46 pm
I am after some information if possible regarding my current hot water cylinder.
I need to replace it but need to know what would be best to change it with. And can try to obtain some quotes, and know that I am getting what I need not overpriced equipment that i do not require.
Basically I have a copper cylinder with two immersion heaters, one at the top and one at the bottom. Although it is one cylinder it is split into 2 parts, i believe the top section should carry cold water, but the water is very hot and over flowing down the overflow pipe.
The cylinder has a cold inlet and hot/cold exit to the taps. An overflow at the top.
I would like to install a new more economical unit which is smaller. I have a 2 bed 1 bath&shower flat.
The current cylinder is about 5 foot.
I do hope this post makes sense and someone can provide some advice or recommend a trademan in the London area that can provide a qoute to supply and fit a new unit.
Jon
Jon
