by roger196 »
Mon Dec 24, 2007 3:58 pm
First make sure there is no air trapped in the pump by bleeding it. ( slightly unscrew large screw in centre).
The pump must be installed with the shaft horizontal. If this is not done, uneven wear on the bearings occur which lead to screeching. If this is the case, get the installer back to replace the pump.
Look at wilo.uk and search on gold50 for installation details.
Another possible cause is grot in the system caused by failing to flush and adding inhibitor.
