New thermostat
Posted: Tue Jan 08, 2008 5:59 pm
by Danc
Hi, I need to change my central heating room thermostat and am considering a digital type. My current stat is 2 wire mechanical type and i have been told i need battery powered type as there is no permanent live feed.
Is this a simple DIY job and does anyone have any suggestions as to which type / maufacturer would be best as there seem to be hundreds?
Many thanks.......
Posted: Tue Jan 08, 2008 10:30 pm
by marrtin
All the digital type of room stats are two wire, in fact it was only the old mechanical types that needed the third wire (a neutral) to work accurately.
A room stat is very easy to change particularly if you only have two wires to start with anyway!
Re: New thermostat
Posted: Tue Jan 08, 2008 11:13 pm
by Danc
[quote="Danc"]Hi, I need to change my central heating room thermostat and am considering a digital type. My current stat is 3 wire mechanical type.
Many thanks.......[/quote]
Posted: Wed Jan 09, 2008 9:00 am
by marrtin
Don't think there is a lot to choose between manufacturers. The only difference really is do you want a straight forward room stat or do you want a programmable one where you can set different temperatures at different times of the day.
Just leave the neutral unused. It does not effect the boiler operation.
