Hot Water & Gas Fine But Central Heating Will Not Come O
Posted: Fri Jan 11, 2008 3:37 pm
by Tommo_1982
I have recently moved into a new property, I can get hot water and gas no problems but no central heating. I have checked the timer and thermostat both are swithced on as they should be but there is no heating comming through at all. When the heating should come on the boiler dosent seem to be doing anything either. Any help would be very much appreciated.
HELP!
Posted: Fri Jan 11, 2008 4:20 pm
Boiler make and model ?
system type ?
pumped heating and water ?
gravity hot water ?
combi boiler ?
Is the pump running ?
more info needed
