Living flame gas fire ventalation
Posted: Sat Feb 23, 2008 12:27 am
by robby
I have a ‘living flame’ gas fire in my living room with an air brick through an outside wall to provide ventilation.
Problem is the draft from the air brick is very strong (and cold). Would an air brick behind the fire (same outside wall) provide adequate air flow?
The ‘burner’ part of the fire seems to be contained and air would be drawn round the fire and in the front, the same as from the original air brick.
Posted: Sat Feb 23, 2008 4:19 pm
Read your fire manufacturers instructions - it will state the amount of ventilation required.
You can place the vent anywhere - in the same room as the fire. The pull from the flue will draw air into the room via the vent - so it doesn't have to be in a place where wind/air is forced into the vent.
Hope this helps
Posted: Tue Feb 26, 2008 6:30 pm
by robby
Thanks for that. I will be closing the air vent and fitting one behind the fire. Cheers.
Posted: Wed Mar 05, 2008 9:09 pm
by gjp
[quote="robby"]Thanks for that. I will be closing the air vent and fitting one behind the fire. Cheers.[/quote]
DONT fit air vent in flue/fire opening-consult your local CORGI Registered engineer to find out why not. gjp
Posted: Thu Mar 06, 2008 8:10 am
What do you mean by behind the fire ?
You can't fit an air brick inside the fire opening.
living flame ventilation
Posted: Fri Mar 07, 2008 3:15 pm
by gjp
robby seems to think you can, htg eng.
