by htg engineer »
Mon Feb 25, 2008 6:56 pm
It could be and sounds like a fault with the pressure relief valve,
What have you been taking the pressure to ?
the Presssure relief valve will normally open between 3.0 and 4.0 bar. If it's leaking outside - at 1.0 - 1.5 bar then replace the PRV and all should work fine.
