CONSTANT?
Posted: Thu Mar 06, 2008 6:35 pm
by trevor123
hi all, if i set my timer for my hot water to constant will my boiler boil water continously or only when there is room in the cylinder to store it?
________
Yamaha DT400
Posted: Fri Mar 07, 2008 10:00 am
All depends on your system. If you have a tank thermostat then it will only fire up your boiler when you need the water heating. If not then every so often it will fire up and circulate and if it is already hot switch off again. The name boiler is maybe wrong they do not boil water there is a sensor inside which limits the water temperature.
Posted: Fri Mar 07, 2008 4:02 pm
by trevor123
so in effect, to put my hot water onto constant would be cheaper than running the immersion and save all the medling with the system by changing or adding timers and such? thanks
________
medical marijuana dispensaries
