by Kenj »
Tue Mar 11, 2008 11:44 pm
Hi crol,
No I experienced exactly the symptoms I described in my first property, and I had a two pipe system. The main problem is due to insufficient water pressure. The hot water flow to the taps relies on being pushed by the cold water in the cold water storage tank. The higher the cold tank is above the hot tank the greater this pressure is, resulting in a higher flow to the hot taps, shower etc. Also hot water from the cylinder could very easily rise up the open vent pipe and discharge into the cold tank rather than flow into your bath. An expensive waste and very irritating when you only get half a bath.
Have a look some of the other discussions on this topic.
The plumbing forum - thermostatic shower flow - for instance.
