I have zero pressure in the boiler.
Posted: Tue Mar 11, 2008 11:10 am
by cherrycheryl
I took a radiator off the wall to decorate; now it is not filling up and there is no hot water and the pressure on the boiler is zero and is not lit. It is a combi boiler. I put the radiator back on exactly in reverse. Help.
Posted: Tue Mar 11, 2008 9:36 pm
The answer is in the question - the boiler pressure is on 0,
Re-pressurise the system and the boiler will work. The pressure gauge should be between 1.0 and 1.5 bar.
Re-pressurising is fairly easy, but there are different ways of doing it depending on the boiler, read boiler manual.
