by ericmark »
Fri Mar 21, 2008 11:00 pm
Sorry to say we had problems although not with the wireless cylinder thermostat. A disturbed wire behind the programmer short circuited and because the fuse was wrong size (13 instead of 3 amp) this burnt out micro switch in motorised valve. Now must wait until after Easter before either repairing or replacing electric head on valve. But the radio link does work even with a long route and sender wrong side of the tank. The LCD window on sender shows temperature set and if the tank is at the correct heat or not. The unit at the boiler shows when heat is called for with red light and quick flash of green as information is updated. Found sender too small for surface box and I need to add a blank plate.
