ariston leak
Posted: Sun Mar 23, 2008 10:42 am
by achill
i have an ariston system boiler with a small leak from the pressure relief valve, which over a few days allows the pressure to drop and thus the boiler locks out, then i have to top it back up has anyone got any ideas?
Posted: Sun Mar 23, 2008 7:23 pm
If pressure is not too high, then the pressure relief valve is passing.
Try opening pressure relief valve a few times, this can sometimes re-seat them.
If not, replace pressure relief valve - normally straight forward.
Posted: Sun Mar 23, 2008 8:42 pm
by achill
when boiler on max the pressure reaches 3+bar then the leak becomes heavier
ariston leak
Posted: Sun Mar 23, 2008 9:27 pm
by achill
pressure increases to above 3 bar then the pressure valve opens even more
Posted: Mon Mar 24, 2008 10:15 am
Possibly a problem with the expansion vessel.
Look in this forum at posts by andy2010
Posted: Mon Mar 24, 2008 12:31 pm
by achill
can it be topped up with air or do you know if it would need changing thanks for your help.
Posted: Mon Mar 24, 2008 12:46 pm
Can sometimes be re-pressurised to 1.0bar using a foot pump or similar.
Drain boiler so there's no pressure - lock open the pressure relief valve, Then pump to 1.0bar and refill system.
See if there's air at the valve on the expansion vessel. The valve looks like a one off a car or bike, If there's air then re-pressurising may work, if there's water then a new expansion vessel is required.
