HELP NEEDED !!! NEW PATIO GONE WRONG !!! :(
Posted: Tue Sep 30, 2008 11:25 am
by Diamond Geezer
Hi to you all, I am new member, with a new post ! 8)
Got problem with a newly laid patio & block drive. Didn't know you was supposed to leave a newly patio alone for a number of months to rid it of efflorescence etc, nor did the sealer company tell me, they said it would be ideally to put on a new laid drive & patio....So I sealed it after two weeks thinking, I was protecting my investment. Now I have a problem & read up on the issue, I understand more, but too late !!!
I really hope someone can help me, I bought Renotex-Drive Sealer 10 % & 20 % formula.
I washed blocks/patio left to dry Sunday 21st (hot sunny day) once all dry put on the 10 % mixture to patio.
I now have a patio 30 SQM which has at least half of the slabs (bradstone riven autumn cotswold) turned white & the rest have different colour patches, when they should be uniformed beige as when it rains !
Spoken to Renotex, who suggested from me to use the test pot of xyelene thinners which they sent to me, to unlock the sealer & this would resolve the issues which I have encountered with the product, white patches & un-uniformed colour on certain the slabs. I have followed the procedure with the xylene & can confirm little difference can be noticed. Although complete white slabs have gone, they suggested I keep doing this. GRRREAT ! :evil:
I have my own theory, that I sealed it & the ground under the slabs was damp & I sealed the damp in. Hence why all the all white slabs have gone, The Slabs themselves have slight random colours, which are now more noticeable. Also speaking to a cleaning & sealing company who use to use this product say it very hard to put on evenly (I rolled) so I might have various thickness on the slabs which doesn't give me a uniformed appearance, this is why they stop using it, as it was too difficult to handle.
Local Companies, suggest leave it for a month or two, see how it goes, then if now better Xylene, hot wash, then ER it. Then leave until the spring of 09 & do the same again, then re-seal in the summer.
Any suggestions you have would be greatly appreciated. As currently It's not right.....
Thanks to all.
Posted: Tue Sep 30, 2008 5:14 pm
by TheDoctor4
Have you had a chance to have a look at the DIY Doctor projects area: https://www.diydoctor.org.uk/projects.htm There is a project called "Brick & block paving " that may be of some help to you!
Regards
