Laying imprinted concrete
Posted: Thu May 17, 2012 12:07 pm
by welshgirl
Just had a firm to quote me on putting down imprinted concrete at the front + back of our semi-detached house due to frost making holes in our current cement paths. They want to bring up the old cement and go down about 8 inches to lay better foundations and put in better drainage. Currently the whole garden only feeds into one small drain. They want to channel some of the water to go into the main drain. But my concern is will going down about 8 inches with a pneumatic drill do any damage to the house. Will the vibrations cause damage to windows, walls around the garden etc. I originally wanted a quote because the appearance of the cement paths don't look that pretty but it sounds like a much bigger job now and I am concerned that if the job is not done right will I be dealing with trying to fix much bigger problems.
Any advice would be grateful.
Re: Laying imprinted concrete
Posted: Thu May 17, 2012 9:11 pm
by welsh brickie
its highly unlikely the jackhammer will damage your property,the work you discribed they are going to undertake sounds correct,but always use a company that has been recomended by friends or family and get a minimum of 3 quotes.Do your groundwork before committing to any contract..
