Building a Base for a Concrete Cupboard
Posted: Wed Dec 07, 2016 1:15 pm
by fatfei
I want to have a go at building a concrete base to build a brick cupboard outside backing onto an extension. It'll be 2ft by 6ft ... Not sure what depth I'll need. How many bags And what type do should I get?
Re: Building a Base for a Concrete Cupboard
Posted: Wed Dec 07, 2016 6:02 pm
by welsh brickie
you will need bags of concrete mix, cement and a concrete mixer which you can hire. you can either dig out and lay a foundation or lay it above ground.
I would build a timber frame work on compacted level ground, And fill it with concrete.
The depth of the concrete should be a minimum of 100mm thick, A ton of concrete mix is needed and 8 cement
Posted: Thu Dec 08, 2016 11:20 am
by fatfei
welsh brickie wrote:you will need bags of concrete mix, cement and a concrete mixer which you can hire. you can either dig out and lay a foundation or lay it above ground.
Thanks Welsh brickie
