Solutions for Laying a Patio on Uneven Ground
Jeuflo
by Jeuflo » Tue May 14, 2019 11:06 am
I'm in the process of laying a patio. The patio is only 2.4m x 2.4m so not too big and a relatively simple job.
I've dug out 150mm to allow 80mm of hardcore, 40mm of sand and cement and 30mm for the paving slabs.
Now the problem I have is that the ground isn't level. I've put some pegs in and measured and simply put, the ground on the left hand side is approx 90mm higher than the ground on the right hand side.
I'm allowing for a 30mm drop to go from left to right. So, if I start at the highest side, by the time I get to the lowest side, the patio will be around 60mm higher than the ground.
If I start at the lowest side, the ground will be 60mm higher than the patio.
Do I need some edging stone or something similar?
Or alternatively could I do a steeper drop so the difference isn't as much, say 60mm drop instead. So the patio would be 30mm higher than the ground on the right hand side.
The patio will be no where near the house. It will be at the bottom of the garden and will be used for light traffic. I.e. sitting out with a few chairs.
Any help would be appreciated.
It is currently Sat Dec 28, 2024 10:39 am
