Concrete or floor screed?
TONYTONE
by TONYTONE » Wed Oct 03, 2007 6:59 pm
Hi guys,
My backroom floor has sunk by 65mm over the years (built in 1910). I bought the house 3 months ago and realised straight away that it was out by allot.
The highest to lowest point is about 65mm and it slopes down to the middle from all sides.
Due to cost I'd like to level it myself but could do with some advice.
Should I start with a concrete mix and finish off with 10mm of self levelling, or a sand and cement screed with fibres in it?
The ratios I've found so far confuse the hell out of me.
Cheers in advice guys
Tone
LCL
by LCL » Fri Oct 05, 2007 7:31 pm
Tonytone
First things first. Is the floor still moving? If it is, then the problems will be magnified if you just lay a new floor on top of it. I assume your floor is concrete, as your note does not say.
To answer your question directly, I would suggest a screed if you are accurate with a trowel or both if your are not. Use a 1: 5 / 1:6 cement : sharpe sand mix and get a 100mm wide level around the room. This will be easer to manage than trying to level the whole floor at the same time. Do this job on day 1. Adding fibres will add strength. Not really needed if you are laying it on a concrete base. Good idea though if it is going over insulation.
On day 2, infill the floor with the same mix, using the day 1 levelled perimeter as a guide for your straight edge. Start at the furthest area from where you will be barrowing in the screed from and level of a barrow load at a time. Tamp with your straight edge and trwol it with a wooden trowel. Try to get it as compact and level as your can. If there are a few hollows afterwards, now is the time to use your latex / self levelling screed. (one the screed is dry)
Sounds hard but its quite a basic job.
Have fun.
LCL
TONYTONE
by TONYTONE » Mon Oct 08, 2007 12:34 pm
LCL,
Cheers for the response. The floor I'm laying onto is concrete. It has some cracks in it but they appear to be quite old so I can only assume that they have stopped moving. If not I'm sure it will let me know LOL.
The 1:5/1:6 cement : sharp sand mx, If I'm correct I need to add water (or something wet). If so how much?
I think I'll put the fibres in anyway. From what I've read they don't appear to have any detremental affect on the mix other than to strengthen which will bode well as the mix gets thinner towards the edges.
Cheers again.
Tone
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jul 26, 2010 7:59 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Thu Jan 09, 2025 12:57 am
