dry rot in a trellis outside
Nina
by Nina » Sun Apr 29, 2007 3:59 pm
I have dry rot in a trellis outside my house. The trellis is only a few centimetres from my basement door - what are the risks that the rot could spread to my house?
I am replacing parts of the trellis, which supports several mature climbing plants. What precautions should I take to stop re-infection and spreading?
Thanks in advance for any advice you can offer.
tucny
by tucny » Fri May 04, 2007 9:19 pm
The first thing i recommend is a correct identification of the fungi. Dry rot does not usually infect external timbers as it prefers damp, humid, dark, enclosed areas poorly ventilated areas. Many wet rot fungi are mistaken for dry rot because of the dry brittle appearence. the terms dry rot and wet rot can be quite misleading as both fungi require food (timber) and moisture.
Should the problem be of wet rot, its easily solved. remove the food(timber) and thats that. Any new timber should be treated.
It is currently Sat Dec 28, 2024 7:07 am
