Air Bricks in house
Posted: Sat May 09, 2009 7:27 pm
by fcwoods99
I know over the years ground level has been lifted on my house and needs lowering !
At the moment my ground level around the back of the house is 3inch above air bricks !
How far below air brick should ground level be ?
Posted: Tue May 12, 2009 9:41 pm
fcwoods99,
The ground level should be at least 2 courses below the DPC level, If the air bricks were installed correctly they should then be above ground level.
Posted: Wed May 13, 2009 11:26 pm
by rosebery
I've just given fundamentally the same answer in your other thread without realising you had created two. One thread is normally enough for each problem.
Air Bricks in house
Posted: Thu May 14, 2009 10:03 pm
by fcwoods99
glad you noticed
cheers for help :D
