What are the conditions supposed to be under floorboards?
deborah75
by deborah75 » Fri Sep 25, 2009 12:17 pm
I've had an awful rotton bin type smell in my living room for the last few months. It appears to be coming from under the floorboards of our ground floor Victorian room. I removed the floor vent to have a look and put my hand in, and the sand type stuff (sorry I'm not very knowledgeable in the area) is wet.
Is this normal? Or do I have a problem?
Dan the man
by Dan the man » Fri Sep 25, 2009 9:56 pm
No this is not normal, you have a small leak coming from somewhere, you may have to take a few more floorboards up and investigate, if water isnt coming through the ceiling then it may only be a slight leak coming from a radiator pipe!
I would take the floorboards up though before it gets worse.
acsimpson
by acsimpson » Mon Sep 28, 2009 4:28 pm
On the ground floor of a victorian property could the damp be coming from below? Do you know if the property has any sort of damp proofing in it?
It is currently Sun Dec 29, 2024 5:28 am
