"Dpc" level with externall Path
LAB
by LAB » Tue May 08, 2012 12:13 pm
1950s house, need to demolish and new build lean-to, house finish floor in to lean-to is only about 50mm above external concrete path, I will need, I assume 150mm, only remedy is to lower the path, this is not an option, not sure if there is DPC, help please
Re: "Dpc" level with externall Path
by welsh brickie » Wed May 09, 2012 9:13 pm
you need to install a drainage system, ACO for example supply the ideal system for your needs.
LAB
by LAB » Thu May 10, 2012 11:30 am
Thanks for that advice, I have heard that 450mm cavity tray will do.
Diolch
It is currently Wed Dec 25, 2024 5:32 pm
