Lectros osmotic
Posted: Sun Aug 19, 2007 12:18 pm
by Ktay
Hi, i am currently stuck in limbo, we have just had a survey completed on a mid terrace house and the report has come back with rising damp on joining wall, and other walls, roughly about 10-15 meters would need treatment. They say in quote 'remove skirtings, hack plaster 300mm, drill n inject chemical damp proof course, re-plaster incorporating waterproof agent, supply n fit new softwood skirting, skim finish' estimated work £700. I am wondering if that sounds reasonable or if it is worth/possible to have the lectros electro osmotic damp proofing fitted. Don't know cost of lectros, was wondering if anyone has any advice, thankyou.
Posted: Tue Aug 21, 2007 8:06 am
by thedoctor
Click into any one of our damp projects and ring the company at the top (Property Repair Systems) They offer free advice (no obligation) we have worked with them for over two years and have only good things to say about them. They can also tell you hoe to install your own DPC if you wanted to. See our projects on damp proof injection.
Posted: Tue Oct 02, 2007 5:30 pm
by knocks
Hi, Same situation as you really, in process of purchasing a mid terraced 100 year old house but survery bought up damp on alot of internal and external walls! Had another report done by an expensive but reputable company and they advise these sort of houses really benefit from electro osmosis treatment and is the best way to go. Injecting into old brick etc doesn't really work alot of the time apparently! It cost pennies to run and they offer a 30 year guarantee but lasts longer. The cost is £2.250 but if it is a long term home well worth it and without alot of mess hopefully. This quote comes from the midlands so don't know if it is more expensive down south.
Hope this helps good luck.
Lectros osmotic
Posted: Mon Oct 15, 2007 9:01 pm
by Perry525
The type of house you describe built in the 1880's was built of porous bricks, tiles, whatever. The builders did not have todays waterproof materials. These houses were built damp, very often with lime that can take years to dry out and on some very thick walls never do.
Keeping this in mind, is your house really damp? Or is it just someone's opinion? There are a lot of people about who make money out of finding damp. And then charging the earth to put it right. Most building materials, well clay based, always have a degree of damp.
Posted: Sun Mar 06, 2011 3:37 pm
by Dampee
knocks wrote:Hi, Same situation as you really, in process of purchasing a mid terraced 100 year old house but survery bought up damp on alot of internal and external walls! Had another report done by an expensive but reputable company and they advise these sort of houses really benefit from electro osmosis treatment and is the best way to go. Injecting into old brick etc doesn't really work alot of the time apparently! It cost pennies to run and they offer a 30 year guarantee but lasts longer. The cost is £2.250 but if it is a long term home well worth it and without alot of mess hopefully. This quote comes from the midlands so don't know if it is more expensive down south.
I have recently tried to claim for recurrence of rising damp, but was told that Lectros was taken over by Wykamol in 1997 and they no longer have anything to do with the old company, and are not responsible for their work. The people who now own Lectros Guarantee Co Ltd have now dissolved the company. The 30 year warranty in not worth the paper it's written on. [/quote]
