Extension inner wall.
frales
by frales » Sat Dec 29, 2007 11:05 pm
I have been left high and dry by some builders and I am now trying to finish an extension. I have checked cavity wall projects for the answer but it is not clear.
As far as I can see the walls are of breeze block on the outside, a cavity and then timber frame. Then there is wool type insulation, a sheet of polythene and then plasterboard. Is this correct?
Should internal walls be the same or only walls to the outside of extension.
Any advice asap greatly appreciated.
It is currently Mon Dec 23, 2024 7:27 am
