Painting on wall after removing artex
Posted: Sun Nov 23, 2008 1:07 pm
by dionne_ward
I have recently removed artex from my walls in the hall, stairs and landing. I have started painting the walls but the top part of the walls are showing brown stains through the paint. I have tried painting it with diluted PVA before painting. What can I do?
Posted: Mon Nov 24, 2008 9:33 pm
by topdec
they are probably water stains, you need to paint over them with an oil based pased paint, eg. stainblock, undercoat etc.
Posted: Mon Nov 24, 2008 11:15 pm
by chris_on_tour2002
firstly you need to try to establish what is causing the stain. could it be damp? if so, you need to investigate to establish the cause and then remedy before tackling the stain.
if it is benign then a stain block is all that's needed. try a primer by the name of bullseye (made by a firm called 'zinsser') which has excellent stain blocking properties. if that doesn't work then try a damp seal such as aquaseal.
pva will probably not work very well as a stain block depending on the type of stain that it is.
Posted: Mon Jan 26, 2009 8:50 am
by TheDoctor5
