Painting a stained front door
Posted: Fri Mar 20, 2009 8:14 pm
by cutiecat
Our front door has a dark stain on it and then a thin layer of varnish. I would like to paint the exterior side a black gloss and the interior a satin white. Do i have to do anything to the door before painting other than sanding it down? I am particularly concerned about the stain bleeding through on the white side, will I need a primer?
Posted: Sun Mar 22, 2009 4:48 pm
cutiecat,
Almost impossible to predict what will happen.
Try using some oil based undercoat on a small area on both sides of the door, you will soon see if bleed through is going to be a problem.
Posted: Sun Mar 22, 2009 8:15 pm
by cutiecat
stoneyboy - Thank you for replying. I did wonder about an aluminum undercoat? Also do I have to sand the varnish off completely or just key it?
Posted: Sun Mar 22, 2009 8:37 pm
by rosebery
Use Zinsser BIN on it.
Posted: Mon Mar 23, 2009 9:36 pm
by rigga
As Rosebery has suggested Zinsser bulls eye, brilliant product but be aware there are three types, a solvent based, a spirit based, and water based. I personally would use the water based one. We don’t know if the door was stained originally with a spirit based stain or an oil based stain. The water based sinister will seal the oil based stain and the top coat would seal the spirit based stain if it bleeds through. Prep your door well and apply 2 cts this can be tinted to a grey with a universal tinter for the black side, then finish with an oil based gloss.
