celing paint
Posted: Fri Apr 17, 2009 3:42 pm
by floorlayergrant
hi any ideas guys?
am decorating an old house and painting the celings is a pain because the former owner had a leak come through in the lounge, im using a stain stopper paint but as im rolling it on the old paint that was bonded well its coming off i thought about plasterboarding it just wondered if anyone knows an easier way?
Posted: Sat Apr 18, 2009 2:35 am
by demon
if anything is loose, scrape back to sound adhered paint, lightly fill, sand and apply stainblock. Then paint in emulsion.
If all the old paint is flaking you could try sealing with pva first.
Posted: Sun Apr 19, 2009 9:10 am
by floorlayergrant
thanks for the advice demon i'll try scraping all over then pvaing it hopefully that will do it.
cheers
Posted: Sun Apr 19, 2009 7:54 pm
by rosebery
Oh no! For goodness sake DO NOT use PVA. Your new paint will not stick to it and thats probably the reason the current stuff is coming off in the first place.
Scrape the old stuff off and start again.
If you've got a mess after stripping thats too big to fill then the simplest, cheapest and quickest solution is to run over it with a couple of coats of textured paint.
