Help! I painted new plaster without sealing the wall first!
Posted: Sun May 10, 2009 9:11 pm
by GillandNob
I've recently had my hall walls skimmed and having waited several weeks for the plaster to dry out I went straight ahead and painted a single coat
of matt emulsion directly onto the walls.
I realise now that I should have sealed or primed the wall first. What should I do now?! Should I wait a few weeks and see how it fairs, sand it down and try sealing the walls afresh or just carry on painting and hope for the best?
Posted: Tue May 12, 2009 9:53 pm
GillandNob,
wait a few weeks and see how it fairs.
Posted: Wed May 13, 2009 11:50 pm
by rosebery
What sort of matt emulsion? It can really make a difference.
If it was "rich matt" you are in trouble as it doesn't stick to new plaster and will have to come off. As emulsion paints take an average 30 days to fully cure you might as well start now. Ditto if it was silk - I know you said matt but just for completeness I mention that.
If it was cheap and very thin own-branded stuff from one of the sheds you may get away with it as there is so much water in it that using it neat is tantamount to a mistcoat with Dulux Vinyl Matt.
If it was "supermatt" again you'll probably get away with it but I bet you didn't half get through a lot of it if it wasn't thinned for the first coat.
If it was "paint for new plaster" it should be OK but you've overpaid for your paint as its just marketing hype and fancy packaging.
BTW when you say "seal and prime" the way you do this is with a mist coat of watered down emulsion paint. Nothing else!
Come back with the type of paint you've used (unless I've given you the answer above) and lets see where we can go with it.
Posted: Fri May 15, 2009 9:54 pm
by GillandNob
Thanks rosebery.
All i can tell you about the paint is that it is ACS Antimould emulsion-
although it does say on the tin that it's a premium quality water based emulsion. That sounds promising but not sure if it is
What do you think?
Re: Help! I painted new plaster without sealing the wall first!
Posted: Fri Mar 01, 2019 3:15 pm
by thedoctor
Painting new and freshly laid plater can be a tricky job and it you are new to DIY, one that you might not be aware of.
If any further readers of this post would like to know how you should paint new and freshly laid platser,
see our painting new plaster project here
