flock wallcoverings
Posted: Sun Feb 07, 2010 7:44 pm
by mitch 01
any advice or tips on hanging flock wallpaper considering its a black faced pattern on a white back any advice will be appreciated
Posted: Mon Feb 08, 2010 3:12 pm
by chris_on_tour2002
most important thing is to avoid getting adhesive on the paper surface - a clean pasting table is imperative.
flock wallcoverings
Posted: Mon Feb 08, 2010 6:14 pm
by mitch 01
cheers chris appreciated also do you neccesarily need to use a felt roller or will a normal hanging brush suffice whilst smoothing out
Posted: Tue Feb 09, 2010 8:13 am
by theshedman
Hi mitch, as chris says the most important thing is try and avoid getting paste on the front of the paper and to use a heavy duty ready mixed paste. I would not use a roller of any sort myself as it may mark the flock. I would use a paper hanging brush but hold up a peice of clean lining paper between the paper and the brush to to help against marking it. Also unless you have a very good finish to the walls I would use lining paper on them, hanging it horizontally to avoid getting any of the joins in the same place place as the top paper.
