painting over varnished wood
Posted: Thu Mar 15, 2007 10:25 am
by Smokey
Can anyone tell me the best way to paint over varnished wood paneling?
I want to apply vinel mat paint for the finnish. Should i just use suger soap and then paint over I doon't really want to do a lot of rubbing down.
Posted: Thu Mar 15, 2007 7:44 pm
by mikester
It all depends what state the existing varnish is in. If its okay with no cracks or flaking then you should get away with just a light rub over with a 240grit sand paper just to give the paint a key and a wipe over with white spirit to remove the dust, other wise its a case either chemical or manual removing of the varnish.
When you do paint be sure to use an oil based under coat and an oil based vinyl matt top coat.
Posted: Fri Mar 16, 2007 12:54 pm
by thedoctor
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE
www.diydoctor.org.uk/projects.htm
Posted: Sat Mar 17, 2007 3:00 pm
by Smokey
Thanks to u both. I didn't think that u could get oil-based vinyl matt - you learn something everyday :) :D BTW the varnish is in good condition so i might just go that route.
Posted: Thu May 10, 2007 10:10 am
by tizfreespirit
Hi there I noted on your question, you said you didnt realise that you could get a vynl matt that was oil based, I cant seem to find one so I wondered if you did if so what make where etc. Regards trish
Posted: Sat May 12, 2007 10:45 am
by Smokey
I think they were tslking about Eggshell oil based paint:
Links removed as they could be advertising. Advertisers should go to our page
www.diydoctor.org.uk/trade.htm
hope it helps
Posted: Sat May 12, 2007 10:48 am
by Smokey
[quote="tizfreespirit"]Hi there I noted on your question, you said you didnt realise that you could get a vynl matt that was oil based, I cant seem to find one so I wondered if you did if so what make where etc. Regards trish[/quote]
I think they were talking about eggshell paint:
Link removed as it could be advertising. Advertisers should go to
hope this helps
