Using Oil-Based Paint Over Water-Based Primer on Exterior Woodwork?
Zacccc
by Zacccc » Fri May 20, 2016 12:55 am
I renewed some exterior woodwork, which I am going to paint with oil-based paint. I first primed the wood with a B&Q primer which was erroneously described as "solvent based" on their website. When I came to clean the paint brush I realized the primer was water based. Can I use oil-based paint over this primer as this is the same paint that I've used on the surrounding woodwork which didn't need renewing? Thanks for any advice on this.
It is currently Fri Nov 15, 2024 6:58 pm
