Replacement Needed for odd Sized Moulded Doors
Posted: Wed Oct 11, 2017 3:30 pm
Hi all,
So I am wanting to replace two odd sized moulded doors in my hallway for a cupboard that previously stored the old warm air system which the precious owners turned into storage.
The current doors are 465mm wide by 1640mm high and I know from all my research this height does not exist as a standard meaning the current ones have been cut?
However I don't believe you are meant to or can cut that much off of a moulded door so WTF can I do as I am literally lost at the moment.
Reason for replacing is one it's backed with I believe asbestos board ( fireproofing?) and two has air grates attached so can't then remove and make them any good.
Cheers all,
N
Cheers all,
N
