Sealing Edges of Previously Peeled Silk Paint Before Re-Painting
Posted: Sun Nov 04, 2018 8:05 pm
by Duno
Hi Guys,
Got a problem that I can't solve so I need help from the good people here cos it's starting to get on my t*ts : (
Basically my walls were painted in white silk emulsion years ago. Walls have been fine to date. The problem is I ended up making a few holes in one of the walls so while repairing it I only went and made it bigger and worse. As I was prepping the area (sanding, filling holes and sanding again), parts of the existing silk paint started peeling so I ended up with a foot of peeled paint. I applied some filler to the edges and sanded to feather it out then painted again with silk emulsion. Started off looking smashing and seamless, then the outer edges started bubbling and now it looks like sh*t. See attached photo.
It seems moisture from the new paint has wet the outer edges of the old paint which has caused it to bubble. So I'm guessing I need to strip it back again and somehow seal the outer edges of the peeled paint BEFORE re-painting? If so, what sealer do I use?
Would be most grateful for any help at all guys!
Much thanks in advance
Re: Sealing Edges of Previously Peeled Silk Paint Before Re-Painting
Posted: Sat Nov 10, 2018 12:52 am
by DocMartin
Can't see any photo. You could try thinned PVA. Maybe 1:3 PVA:water?
Posted: Mon Feb 18, 2019 11:45 pm
by gc1967
Scrape off all the flaking paint and apply stain block and then fill and lightly sand and touch in filler with stain block and then repaint your wall / walls.
