Toilet waste lengths
russellfl
by russellfl » Mon Jul 07, 2008 5:43 pm
Hi, can anyone tell me if there is a limit to the length of a toilet wast pipe going to the soil stack?
I have a bungalow with a floating floor and would like to put in an en suite toilet in my front bedroom. The distance is approx 9 metres and the drop from the new toilet pan to the rear toilet waste where it could connect to would be about 300mm, if the length is ok would the drop be ok also?
Skids
by Skids » Wed Jul 09, 2008 8:23 pm
Hi russellfl,
Rule of the day is 1:40 drop
Therefore 9000 / 40 = 225mm
Make sure you have access points for then there is a problem and you need to get access to unblock the pipes, always think about how you are going to fix it when its broken/blocked, and you will save yourself a lot of hassle when it does, because we all know it will
Regards
Skids
russellfl
toilet waste lengths
by russellfl » Fri Jul 11, 2008 2:06 pm
Thanks Skids very useful, much appreciated
It is currently Mon Dec 02, 2024 10:56 pm
