Rotating soil pipe junction to move w.c.
Posted: Fri Feb 13, 2009 9:35 am
Guys,
I need to relocate a w.c. from one wall to the adjascent one. This will entail rotating the soil pipe through 90 deg. The soil pipe connects with the stack in the junction of the two walls involved. The soil pipe and the stack are plastic (Push fit I think).
Do you have any hints as to how best to rotate the junction. I dont want to rotate the upper section of the stack or disengage it if possible as the exit through the roof has been problematic in the past.
Is there any way to lubricate the joins to make rotation easier or will brute force suffice.
Appreciate your thoughts,
Doug
Doug
