running drainage under the foor boards?
Posted: Sat Mar 14, 2009 9:19 pm
by sammyantha
hi i want to move a kitchen fro the back of the house to the front. the only problem is that there is not any drainage at the front only at the back of the house , can i run it through the house under the floors? the house is a terace house in the middle so cant run outside and around the side... Help
Posted: Sun Mar 15, 2009 10:31 pm
sammyantha,
Provided you can get the necessary fall it will be OK. Make sure you fit an access T at the exit point so unblocking can be carried out if required.
Posted: Mon Mar 16, 2009 12:20 am
by sammyantha
fantastic thank you, what is a necessary fall?
Posted: Mon Mar 16, 2009 9:23 pm
sammyantha,
An absolute minimum would be 1 in 40, the problem you will have is supporting the pipe every 0.5m. You will also need to incorporate an Air Admitance Valve to prevent siphon action.
