Drain smell coming from bathroom sink
Posted: Sat Feb 05, 2011 2:53 pm
I have a drain smell coming from my bathroom sink. The water is running away fine from the toilet, shower unit and sink and no water is backing up so I am told it can't be a blockage. We have fitted Hepworth and Durgo valves to the toilet and sink and when this didn't work fitted a different type of air admittence valve to the sink but smells are still coming up. I have had the local water board check the public drains as various neighbours said they had experienced problems either outside or inside their properties yet nothing was found. A neighbour also said the drains were smelling in the road last week. I am told it may be some alternation work done in the road but their is no way of knowing and am at a loss as to what to try next as I am told that other symptoms would be present if I had a broken drain or leak and that internal pipework is likely to be too small to put CCTV camera down. Any suggestions gratefully received.
