What tools for lowering concrete wet room floor?
Posted: Tue Feb 15, 2011 11:27 am
I have an existing wet room designed for disabled usage, the floor underneath the lino flooring is concrete with a channel cut in and a drain in the corner.
I want to half the size of it in order to improve circulation on the ground floor and create a compact shower room with a micro basin and wall hung toilet.
The drain currently spans across what I want to be the hallway (indicated by the double line.
| ======o |
The lowered area would be to the right of this image.
What's the easiest way to do this conversion?
I was looking at purchasing one of these to sink in to the floor, but would require lowering the shower tray area by 24mm and then putting the new drainage channel:
Google "cgi.ebay.co.uk/Marmox-wetroom-tray-wet-room-showerlay-800-x-800-/270702224919?pt=UK_Home_Garden_Bathroom_Shower_Units_PP&var=&hash=item84b77e203f#ht_1652wt_906 "
Would I be able to do it with an SDS drill with a chasing bit?
| ======o |
